AgenticFlow
Q: 3.7 sonet
info5749May 3, 2025
SeanP_AgenticFlowAI
SeanP_AgenticFlowAI
May 3, 2025
A: To use Claude 3.7 Sonnet, you'll need to connect your Anthropic API key using our Bring Your Own Key (BYOK) feature in the Connections settings. Using Claude 3.7 isn't covered by the included AgenticFlow credits; you'll be billed directly by Anthropic for its usage (AgenticFlow only charges the small fixed credit cost per step).
Posted: May 3, 2025
Hi Sean, has future AI grows, would you move some of the existing AIs to the 'credit system' ? So say we've moved to Claude 3.9 *future* would the 3.7 get moved to the 'credit system' - I'm concerned the 'credits' will only work with older platforms in the future. Please let me know your thoughts.
Posted: May 3, 2025
Yes, as AI models become more efficient and their operating costs decrease significantly, we absolutely plan to add newer, capable models to the list covered by your AgenticFlow credits when it becomes economically feasible for us to do so within the LTD structure.
We'll always aim to offer a strong set of useful, credit-covered models alongside the BYOK flexibility.
Edited: May 3, 2025
Thanks again Sean. I know your time is valuable. There will be only 2 users our end - but feel the plan 4 might be best. Would you deem the credit plenty for everyday use? And I tested out images - it worked well but couldn't see how to get High Res images. Is this possible?
Think thats all i need to know. Then I'll contact Mark from Tooltilities who may buy this..
Regards.
Peter.
Posted: May 3, 2025
For 2 users, Tier 4's 200k credits/month is generally plenty for everyday use, especially if you leverage BYOK for heavy AI calls. Just keep an eye on your usage patterns in Settings > Usages (we are adding this page).
Posted: May 3, 2025
Yes, getting high-res images is definitely possible! Within our generate_image node, ensure you select an "HD" or "FullHD" option in the Aspect Ratio setting. For even more control or specific high-res models, you can use our replicate_run_model node to call dedicated models on Replicate (requires BYOK), or try our magic_upscale / enhance_image_v2 nodes to upscale existing images.
Posted: May 3, 2025
I have a video for you for Replicate part: https://youtu.be/YGtIH1aegXw?si=_dDBth-qAX3Ye8V5
