Q: 6 Codes Max
I'm confirming that if you max out this deal with six codes the Zapier integration is free correct?
Can you update the 6 Codes max plan in the comparison chart so that it is clear about everything that makes it different then the others. Right now the only difference I see is 2% sales commission. I would hope I wouldn't have to pay extra for Zapier if I stacked the codes to the max. Thanks in advance.
Adrian-forento.io
Apr 8, 2025A: Hey drew498, thank you for the question.
Tier 6 is properly mapped and listed in the descriptions above. The only difference between Tier 6 and the other Start plans (Tier 2 & 4) is that the sales commission fee is at 2% instead of 5% or 10%.
Feel free to reach out through the live chat on our website if you have any additional questions, I'm happy to help.
/Adrian at Forento
And with tier 6 Zapier is included right?
Hey drew498. No, the Zapier integration is configured primarily for accepting external payments and therefore limited to the available addons. With that said, if you need Zapier, you definitely don't need to full-stack the codes. I would recommend getting two codes (Tier 2) and then subscribing to the No Commission Addon.
